- 3.1 Installation Topics
- 3.3 Configuration Topics
- 3.5 PC Example Applications
- 3.7 Kinematics
- 3.8 KFLOP C Programs
- 3.9 ModBus
- 3.10 Linux Support
- 5.9 Max Limits - Error
- 5.12 Bode Plots
- Announcement of our Latest Release (5.3.1) on the Dynomotion Forum
Linux Support
See here for more info.
KFLOP specific Hardware Info
KStep specific Hardware Info
3D Board Models
Roberto Gotti of Powertech)
Cables that connect between Dynomotion boards are normally included when purchasing the boards together. They are also very common and easy to make.Use 16-conductor or 26-conductor ribbon cable (0.05 inch pitch 26 AWG preferrably or 28AWG) and IDC sockets.
