Revision as of 23:03, 28 November 2023 by ICLEAF (Talk | contribs)
Tool Length/Offsets G43Hn G49
Linux Support
See here for more info.
KFLOP specific Hardware Info
KStep specific Hardware Info
Touch Plate Wiring to Konnect
3D Board Models
KonnectHoles.stp.txt
Kanalog.stp.txt
Roberto Gotti of Powertech)
KANALOG_BOARD.stp.txt
KFLOP IDC 连接器和电缆
一起购买板时,通常会包含连接 Dynomotion 板之间的电缆。它们也很常见且易于制作。
使用16 芯或 26 芯带状电缆(0.05 英寸间距,最好是 26 AWG 或 28 AWG)和 IDC 插座。
16 芯带状电缆 3M 部件号 3801/16 100
26 芯带状电缆 3M 部件号 C3801 /26 100
Winford 还销售带状电缆(尽管只有较细的 28 AWG):
36 芯带状电缆 3M 部件号 3801/16 100
https://www.ichome.com/inventory
请注意,您通常可以撕掉电线以减少导体数量。例如,从 26 减少到 16。将导线从标记引脚 1 的红色条纹上撕下来。压接工具
常见:https emoticon/www.amazon.com/Accessories-Crimp-Ribbon-Cable-Connectors/dp/ B007R2JEM4/ IDC 插座 16 针(针距 0.1 英寸)https://www.digikey.com/product-detail/en/assmann-wsw-components/AWP-16-7240-T/HHKC16H-ND/5031953 Assman 零件编号 AWP 16-7240-T
IDC 插座 26 针(针距 0.1 英寸)
Jogging Pendant
Basic Servo Tuning Overview
I Gain/Max Limit Integrator
  2. D Gain of 35
  4. Servo Sample Time of 90us
换刀装置 - 线性铣刀 4 种工具 - C 程序
Spanish
