Revision as of 18:02, 18 August 2017 by SFZ (Talk | contribs)
Touch Plate Wiring to Konnect
I Gain/Max Limit Integrator
  2. D Gain of 35
  4. Servo Sample Time of 90us
Hardware requirements
The only real differences between a CNC machine and a 3D printer are in the tool head and the heated build platform. CNC machines use spindles, but some 3D printers use extruders (hot plastic extruder).
Extruder Nozzle
Heated Bed
Bowden Extruder
&title=-&rs=SecureFileStore::getFile&f=/2/2e/BowdenExtruder.png" alt="" data-bs-imagename="File:BowdenExtruder.png" data-bs-thumb="false" data-bs-thumbsize="180" data-bs-right="false" data-bs-left="false" data-bs-center="false" data-bs-align="" data-bs-none="true" data-bs-frameless="false" data-bs-frame="false" data-bs-border="false" data-bs-upright="false" data-bs-alt="" data-bs-caption="" data-bs-link="" data-bs-sizewidth="false" data-bs-sizeheight="false" data-bs-wikitext="File:BowdenExtruder.png|none|link=" data-mce-src="extensions/BlueSpiceFoundation/resources/bluespice/images/bs-ajax-loader-pik-blue.gif?BowdenExtruder.png" data-mce-style="margin: 0.5em 0 0.8em 0; padding: 3px; cursor: pointer;" border="0">
Metal Bowden Extruder for 1.75mm filament with stepper motor. Can be driven by KSTEP. (e.g.: All Metal V6 Hotend 1.75mm Bowden Extruder Prusa i3, around $25).
Adding a KNozz to your KFLOP
&title=-&rs=SecureFileStore::getFile&f=/d/da/KNozz.png" alt="" data-bs-imagename="File:KNozz.png" data-bs-thumb="false" data-bs-thumbsize="180" data-bs-right="false" data-bs-left="false" data-bs-center="false" data-bs-align="" data-bs-none="true" data-bs-frameless="false" data-bs-frame="false" data-bs-border="false" data-bs-upright="false" data-bs-alt="" data-bs-caption="" data-bs-link="" data-bs-sizewidth="false" data-bs-sizeheight="false" data-bs-wikitext="File:KNozz.png|none|link=" data-mce-src="extensions/BlueSpiceFoundation/resources/bluespice/images/bs-ajax-loader-pik-blue.gif?KNozz.png" data-mce-style="margin: 0.5em 0 0.8em 0; padding: 3px; cursor: pointer;" border="0">
KNozz provides two Thermistor Inputs to allow KFLOP to monitor the temperature of both the Extruder Nozzle and Bed Heater Platform.  12-bit ADC converter provides better than 1 degree C temperature repeatability.
Learn more here:
Software requirements
CraftWare
Video
(Published on Feb 15, 2017)
&title=-&rs=SecureFileStore::getFile&f=/4/4a/Skull.png" alt="" data-bs-imagename="File:Skull.png" data-bs-thumb="false" data-bs-thumbsize="180" data-bs-right="false" data-bs-left="false" data-bs-center="false" data-bs-align="" data-bs-none="true" data-bs-frameless="false" data-bs-frame="false" data-bs-border="false" data-bs-upright="false" data-bs-alt="" data-bs-caption="" data-bs-link="" data-bs-sizewidth="false" data-bs-sizeheight="false" data-bs-wikitext="File:Skull.png|none|link=" data-mce-src="extensions/BlueSpiceFoundation/resources/bluespice/images/bs-ajax-loader-pik-blue.gif?Skull.png" data-mce-style="margin: 0.5em 0 0.8em 0; padding: 3px; cursor: pointer;" border="0">
Spanish
