- 4 2. Control styles
- 5 '3. Control 'attributes
- 6 4. Main Window attributes
- 7 5. Bitmap types, Alpha, and locations
- 8 Dynomotion Hardware Topics
- 9 Axes Servo Tuning and Trajectory Planner
- 9.1 Velocity, Acceleration, and Jerk
- 9.2 Axis Resolution - counts/inch (or counts/mm)
- 9.3 Servo Dither/Hunting - (oscillation around zero error)
- 9.4 Noisy GCode - Trajectory Planner Smoothing
- 9.5 Arc "faceting" - Trajectory Planner - Collinear Tolerance
- 9.6 I Gain/Max Limit Integrator
- 9.7 Bode Plots
- 10 Problems and Resolutions
- 11 Applications and Projects
- 12 International and other Languages
Table of contents:
- Introduction
- Control styles
- Control attributes
- Main Window attributes
- Show/Hide Controls
- Change Label/Button Text
- Change Font/Text Size
- Bitmap Buttons and Labels
- JPG, BMP, PNG Bitmaps
- Toggle Bitmap Labels (LEDs)
- Custom User Entry Controls
2. Control styles
- Label
- Momentary button
- DualLabel
- Select ID
b) Selecting an Action:
- Show/Hide
- Move/Resize
- Main Dialog Screen
- Script File
