- 4 Introduction
- 5 2. Control styles
- 6 '3. Control 'attributes
- 7 4. Main Window attributes
- 8 5. Bitmap types, Alpha, and locations
- 9 Dynomotion Hardware Topics
- 10 Axes Servo Tuning and Trajectory Planner
- 10.1 Velocity, Acceleration, and Jerk
- 10.2 Axis Resolution - counts/inch (or counts/mm)
- 10.3 Servo Dither/Hunting - (oscillation around zero error)
- 10.4 Noisy GCode - Trajectory Planner Smoothing
- 10.5 Arc "faceting" - Trajectory Planner - Collinear Tolerance
- 10.6 I Gain/Max Limit Integrator
- 10.7 Bode Plots
- 11 Problems and Resolutions
- 12 Applications and Projects
- 13 International and other Languages
Table of contents:
- Introduction
- Control styles
- Control attributes
- Main Window attributes
- Show/Hide Controls
- Change Label/Button Text
- Change Font/Text Size
- Bitmap Buttons and Labels
- JPG, BMP, PNG Bitmaps
- Toggle Bitmap Labels (LEDs)
- Custom User Entry Controls
2. Control styles
- Label
- Momentary button
- DualLabel
- Select ID
- Show/Hide
- Move/Resize
- Main Dialog Screen
- Script File
