Table of contents:
- Introduction
- Control styles
- Control attributes
- Main Window attributes
2. Control styles
- Label
- Momentary button
- DualLabel
'3. Control 'attributes
- Select ID
b) Selecting an Action:
- Show/Hide
- Move/Resize
4. Main Window attributes
- Main Dialog Screen
- Script File
5. Bitmap types, Alpha, and locations
I Gain/Max Limit Integrator
