Revision as of 15:02, 12 June 2017 by Sascha F Zeller (Talk | contribs)
Touch Plate Wiring to Konnect
I Gain/Max Limit Integrator
  2. D Gain of 35
  4. Servo Sample Time of 90us
Spanish
