Touch Plate Wiring to Konnect
The idea is that a motor axis has torque and speed limitations and you should determine and understand what they both are for your system. Available motor torque drops off with higher speed. At some speed the motor will not even be able to generate any torque at all. Motor torque is required to accelerate the axis. We need to make sure that no combination of velocity and acceleration will ever cause the axis to fault/stall/fail. So there is often a complex set of speeds and accelerations that will work ok that form an envelope of workable speed and acceleration. So one nice thing to know is top speed possible. It is like taking your car out on a long straight highway and gradually accelerating to find the max speed is 100MPH. You will then know that ever attempting a speed over 100MPH will always fail. Also speed should probably be limited to something like 80MPH to allow for margin and to allow reasonable acceleration up to that speed. The reason for performing the top speed test at low acceleration is to avoid a failure because of not being able to accelerate at the specified rate. So we want to set the acceleration to a low value so it will not be a limiting factor when determining top speed. However if we set the acceleration so low with a short trip distance we will never go very fast and the speed test will be meaningless. This should be avoided. Change the Plot type to Velocity, Output, vs Time to clearly see if this is the case.
View edit history of this page.
