Revision as of 12:39, 31 March 2016 by TK (Talk | contribs)
Its important to understand the resolution of your Axis which is the number of fundamental raw motor/driver encoder counts or motor steps per standard unit of distance (inch or mm).  Although tuning in KMotion.exe Ste Response Screen and motions within KFLOP typically use units of raw counts or steps it is important to know how these translate to real-world distances, speeds, etc...  Later, applications such as KMotionCNC or Mach3 will need this information to scale motions properly.
