#include "KMotionDef.h" #define TMP 10 // which spare persist to use to transfer data #include "..\..\KflopToKMotionCNCFunctions.c" //----------------------------------------- // LINEAR TOOL CHANGING //----------------------------------------- #define AXISX 0 #define AXISY 1 #define AXISZ 2 //---------Absolute position of tool holders #define HOLDER_X_1 100 #define HOLDER_X_2 200 #define HOLDER_X_3 300 #define HOLDER_X_4 400 #define HOLDER_Y 1300 #define HOLDER_Z -200 // absolute position of the tool height setting plate #define TOOL_HEIGHT_PLATE_X 50 #define TOOL_HEIGHT_PLATE_Y 50 // absolute position to move to that is permanently unobstructed, and safe to move down in Z #define TOOL_CHANGE_SAFE_POS_X 250 #define TOOL_CHANGE_SAFE_POS_Y 1200 #define AXIS_SAFE_DISTANCE_Y 100 // distance in mm to approach tool holder //--------- //--------- Spindle IO bits #define CLAW_EJECT 58 // IO bit to eject tool from spindle (KONNECT OUTPUT 10) #define SPINDLE_CLEAN 59 // IO bit to blow air out of spindle taper (KONNECT OUTPUT 11) #define CLAW_LOOSE 1048 // IO bit to sense whether the claw has ejected (KONNECT INPUT 24) #define TOOL_SENSE 1049 // IO bit to sense whether the a tool is in the spindle (KONNECT INPUT 24) //--------- #define TOOL_VAR 9 // Tool changer desired new tool Var // Tool changer Last tool loaded is saved globally in this Var #define LAST_TOOL_VAR 8 // -1=Spindle empty, 0=unknown, 1-4 Tool Slot loaded into Spindle #define TOOL_DISK_FILE "c:\\Temp\\ToolChangerData.txt" #define CLAMP_TIME 1.0 // seconds to wait for the clamp/unclamp #define TOOL_HEIGHT_BIT 1055 //bit to read tool height plate (KONNECT INPUT 31) #define SAFE_HEIGHT_Z 100 // relative distance in mm to move to clear the top of the tool taper #define TOOL_RETRACT_SPEED_Z 5000 //speed in counts/second to move spindle up after tool has been ejected #define SlowSpeed 10.0 //mm/sec #define CNT_PER_MM_X 800.0 #define CNT_PER_MM_Y 800.0 #define CNT_PER_MM_Z 800.0 // function prototypes int DoToolChange(int ToolSlot); int GetCurrentTool(int *tool); int SaveCurrentTool(int tool); BOOL ToolNumberValid(int tool); float ToolPositionX(int tool); int MoveXY(float x, float y, float Speed); int MoveZ(float z, float Speed); int UnloadTool(int CurrentTool); int LoadNewTool(int Tool); int EjectTool(void); main() { int ToolSlot = persist.UserData[TOOL_VAR]; // Requested tool to load (value stored an integer) if (DoToolChange(ToolSlot)) // perform Tool Change { // error, Halt Job DoPC(PC_COMM_HALT); } } // Perform Tool Change. Return 0=Success, 1=Failure int DoToolChange(int ToolSlot) { int CurrentTool; if (GetCurrentTool(&CurrentTool)) return 1; // -1=Spindle empty, 0=unknown, 1-4 Tool Slot loaded into Spindle printf("Load Tool Slot %d requested, Current Tool %d\n",ToolSlot, CurrentTool); if (!ToolNumberValid(ToolSlot)) // check if invalid { char s[80]; sprintf(s,"Invalid Tool Change Number %d\n",ToolSlot); printf(s); MsgBox(s, MB_ICONHAND | MB_OK); return 1; } if (CurrentTool!=-1) // is there a tool in the Spindle?? if (UnloadTool(CurrentTool)) return 1; // yes, unload it // Now Spindle is empty, load requested tool if (LoadNewTool(ToolSlot)) return 1; SaveCurrentTool(ToolSlot); // save the one that has been loaded return 0; // success } // - Load new Tool (Spindle must be empty) int LoadNewTool(int Tool) { // - Move to position of requested tool // - Rapid move to absolute position of new tool only in X and Y if (MoveXY(ToolPositionX(Tool),HOLDER_Y,SlowSpeed)) return 1; // - Move to tool Z position at TOOL_RETRACT_SPEED_Z if (MoveZ(HOLDER_Z,SlowSpeed)) return 1; // - Engage new tool // - CLAW_EJECT and SPINDLE_CLEAN bits are currently high from tool removal operation // - Turn off CLAW_EJECT and SPINDLE_CLEAN bits to engage tool ClearBit(CLAW_EJECT); ClearBit(SPINDLE_CLEAN); // - Wait for time in seconds defined by CLAMP_TIME Delay_sec(CLAMP_TIME); // - Check to see if CLAW_LOOSE and TOOL_SENSE are high; if either are not, // something has gone wrong; halt everything and display message indicating failure // - Tool has been engaged if (!ReadBit(CLAW_LOOSE)) { printf("Claw Still Loose Error\n"); MsgBox("Claw Still Loose Error\n", MB_ICONHAND | MB_OK); return 1; } if (!ReadBit(TOOL_SENSE)) { printf("Tool Sense Error\n"); MsgBox("Tool Sense Error\n", MB_ICONHAND | MB_OK); return 1; } // - Leave tool holder by moving Y axis by the negative value of Y_AXIS_SAFE_DISTANCE // - Move to position of requested tool // - Rapid move to absolute position of new tool only in X and Y if (MoveXY(ToolPositionX(Tool),HOLDER_Y+AXIS_SAFE_DISTANCE_Y,SlowSpeed)) return 1; // - Rapid to Z home if (MoveZ(0.0,SlowSpeed)) return 1; return 0; //success } // - Remove tool in spindle by going to holder of current tool int UnloadTool(int CurrentTool) { // - Rapid to Z Home to clear any work that may be on the table if (MoveZ(0.0,SlowSpeed)) return 1; // - Rapid to TOOL_CHANGE_SAFE_POS to execute a safe negative Z move if (MoveXY(TOOL_CHANGE_SAFE_POS_X,TOOL_CHANGE_SAFE_POS_Y,SlowSpeed)) return 1; // - Approach tool holder by matching Z height of tool flange currently in spindle with tool holder claw if (MoveZ(HOLDER_Z,SlowSpeed)) return 1; // - After matching height above, approach tool holder by moving to holder X position if (MoveXY(ToolPositionX(CurrentTool),TOOL_CHANGE_SAFE_POS_Y,SlowSpeed)) return 1; // - After matching X position, match tool Y position if (MoveXY(ToolPositionX(CurrentTool),HOLDER_Y,SlowSpeed)) return 1; // - Move only in Y position until current position matches tool holder position (maybe disable X) axis?) // ??? // - Eject tool if (EjectTool()) return 1; return 0; //success } // - Eject tool int EjectTool(void) { // - Turn on CLAW_EJECT bit to remove tool from spindle SetBit(CLAW_EJECT); // - Turn on SPINDLE_CLEAN bit to remove any debris from taper and tools SetBit(SPINDLE_CLEAN); // - Wait for time in seconds defined by CLAMP_TIME Delay_sec(CLAMP_TIME); // - Read CLAW_LOOSE bit to see whether the tool is loose, to make a safe Z move without // destroying tool holder // - If CLAW_LOOSE bit is high, something has gone wrong; // halt everything and display message indicating failure if (ReadBit(CLAW_LOOSE)) { printf("Claw Loose Error\n"); MsgBox("Claw Loose Error\n", MB_ICONHAND | MB_OK); return 1; } // - Move Z axis up at speed defined by 'Z_TOOL_RETRACT_SPEED', to Z_SAFE_HEIGHT if (MoveZ(HOLDER_Z+SAFE_HEIGHT_Z,TOOL_RETRACT_SPEED_Z)) return 1; // - Read TOOL_SENSE bit to see whether the tool has been successfully ejected from the spindle // - If TOOL_SENSE bit is high, something has gone wrong; // halt everything and display message indicating failure if (ReadBit(TOOL_SENSE)) { printf("Tool Sense Release Error\n"); MsgBox("Tool Sense Release Error\n", MB_ICONHAND | MB_OK); return 1; } return 0; // success } //return x position of tool holder as a function of the tool float ToolPositionX(int tool) { return (HOLDER_X_2-HOLDER_X_1)*(tool-1) + HOLDER_X_1; } // Get the last loaded tool. Parameter points to where to return tool // First try to get from KFLOP memory // if memory is invalid, try to read from disk // if can't read disk then ask Operator // returns 0 on success, 1 on fail or Operator asked to abort int GetCurrentTool(int *ptool) { int success,Answer,result,tool; float value; tool = persist.UserData[LAST_TOOL_VAR]; success = ToolNumberValid(tool); // check if valid if (!success) // invalid after power up, try to read from PC Disk File { // Try to open file FILE *f=fopen(TOOL_DISK_FILE,"rt"); if (f) // did file open? { // read a line and convert it result=fscanf(f,"%d",&tool); fclose(f); if (result==1 && ToolNumberValid(tool)) { printf("Read Disk File Value of %d\n",tool); success=TRUE; // success if one value converted } } if (!success) printf("Unable to open/read file:%s\n",TOOL_DISK_FILE); } if (!success) // if still no success ask Operator { Answer = InputBox("Tool in Spindle or -1",&value); if (Answer) { printf("Operator Canceled\n"); return 1; } else { tool=value; printf("Operator Entered Value of %d\n",tool); } } if (!ToolNumberValid(tool)) // check if invalid { char s[80]; sprintf(s,"Invalid Current Tool Number %d\n",tool); printf(s); MsgBox(s, MB_ICONHAND | MB_OK); return 1; } printf("Current tool = %d\n",tool); *ptool = tool; // return result to caller return 0; //success } // save the tool number to KFLOP global Variable and to PC Disk file in case we loose power int SaveCurrentTool(int tool) { persist.UserData[LAST_TOOL_VAR]=tool; FILE *f=fopen(TOOL_DISK_FILE,"wt"); fprintf(f,"%d\n",tool); fclose(f); return 0; } // check if Current Tool number Valid // -1 = no tool loaded // 1-4 = valid tool BOOL ToolNumberValid(int tool) { return tool == -1 || (tool>=1 && tool<=4); } // Move Axis XY at specified Speed and wait until complete // return 0 = success, 1 if axis disabled int MoveXY(float x, float y, float Speed) { MoveAtVel(AXISX, x * CNT_PER_MM_X, Speed * CNT_PER_MM_X); MoveAtVel(AXISZ, y * CNT_PER_MM_Y, Speed * CNT_PER_MM_Y); while (!CheckDone(AXISX) || !CheckDone(AXISY)) { if (!chan[AXISX].Enable) { printf("Error X Axis Disabled\n"); MsgBox("Error X Axis Disabled\n", MB_ICONHAND | MB_OK); return 1; } if (!chan[AXISY].Enable) { printf("Error Y Axis Disabled\n"); MsgBox("Error Y Axis Disabled\n", MB_ICONHAND | MB_OK); return 1; } } return 0; //success } // Move Axis Z at specified Speed and wait until complete // return 0 = success, 1 if axis disabled int MoveZ(float z, float Speed) { MoveAtVel(AXISZ, z * CNT_PER_MM_Z, Speed * CNT_PER_MM_Z); while (!CheckDone(AXISZ)) { if (!chan[AXISZ].Enable) { printf("Error Z Axis Disabled\n"); MsgBox("Error Z Axis Disabled\n", MB_ICONHAND | MB_OK); return 1; } } return 0; //success }
