Revision as of 13:25, 28 July 2018 by TK (Talk | contribs)
Specification
Kanalog Hardware/Connectors
BlockDiagram Board Layout
Kanalog Use and Settings
Relay Drivers / Grounding
Logical "AND" of Opto Output and Relay Driver
Both the Relay Driver and Opto Output need to be active to enable the Solid State Relay (SSR).  Such a circuit can be used to assure a SSR remains off until after KFLOP Boots and SWE Relay Driver output goes active and KFLOP is initialized and the Opto Output is activated.
Note positions of the SSR and Opto Output may be reversed if desired.  But because relay driver outputs are internally grounded it must be at the bottom.
There is a starting configuration for KFLOP+Kanalog called KanalogInitialPID.mot in the \KMotion\Motors folder.  Load it into an axis channel from the KMotion Configuration Screen.  The basic first steps are to verify the hardware:
  1. check the encoder counts correctly as shown on the KMotion Axis Screen Position (a KFLOP Axis must be configured as Encoder Input with the Input Channel0 set to the channel where the encoder is physically connected)
  2. check that the DACs can command the Amplifier to control motor speed.  Test Console commands like DAC0=200 to Output ~ -1V (with the axis disabled - if any axis is enabled and continuously writing to the DAC any Console Command will be overwritten)
  3. If steps #1 and #2 above work correctly, enable the Servo using the Step Response Screen.  Zero, Enable.  The motor should then attempt to weakly hold position.
I think our software/documents some what over use the word channel which can confusion. There are Motor Axis Channels, DAC Output Channels, and Encoder Input Channels which are all different things.   This diagram may help:
KFLOP Functional Diagram
Input Channels
The KanalogInitialPID.mot configuration file is an example of a Kanalog Axis using DAC #0 and Encoder #0.  If simply loaded into multiple Motor Axis Channels it will configure all the Motor Axis to all use DAC 0 and Encoder 0 as their I/O devices.
  1. select Axis Channel #1
  2. load the KanalogInitialPID.mot configuration
  3. Change the Input Channel and Output Channel settings to the Encoder and DAC you want that motor to use (ie. #1 and #1)
Max Output For DACs
Note the Maximum Output range for the DACs is +/-2047 DAC Counts.  Attempting to output larger values will cause a wraparound effect and runaway or following error fault.  So set the Max Output to 2047 or less.
Testing Analog Amplifiers
Kanalog is designed to be precise and linear but not highly accurate (+/- 1% components are used).  Absolute accuracy on the servo output is not normally a requirement for good servo control.    This is not a problem when the servo is enabled as the servo will command whatever output necessary to hold the desired position.   However whenever the servo is disabled the Drive should also be disabled to avoid any motor drive or drift.
The Drive enable signals can be interfaced to KFLOP.  Any I/O can be used as the Drive enables are handled in software as a User Program (see the watchenable.c example).
However please note that unfortunately the Kanalog Outputs Power up in an initially undetermined state for several seconds until KFLOP boots up.  If this is a problem for your system then another means of keeping the Drives disabled should be used during initial power up.  The Kanalog SWE Relay Output Driver is guaranteed to remain disabled until KFLOP fully boots and all Kanalog Outputs are initialized to the off state.
