BlockDiagram | Board Layout |
Kanalog Use and Settings |
- 1 Relay Drivers / Grounding
- 5 Max Output For DACs
- 6 Testing Analog Amplifiers
KFLOP Functional Diagram
Input Channels
- select Axis Channel #1
Max Output For DACs
