Revision as of 11:50, 16 October 2015 by TK (Talk | contribs)
Welcome to our wiki where you can find and share knowledge on Dynomotion's systems.  To begin adding information to this wiki, simply create an account and start editing. To make editing pages easier for everyone, we have installed a visual editor by default.  This visual editor allows you to edit a wiki page much like you would a standard word processing document.  Note that Right-Clicking with the mouse is a shortcut way to insert Links or images.  For Spell Correction Ctrl-Right-Click may be used.  Standard MediaWiki editing may also be used or set as the default in your User Preferences  or switched to using the [[]] symbol on the tool bar.
Creating New Wiki Pages
Updating KFLOP Firmware
The error:
  1. Run KMotion.exe
V4.33q
  5. Right Mouse Click "Paste"
  7. Save the file
