Revision as of 12:31, 13 January 2025 by TK (Talk | contribs)
  5. Right Mouse Click "Paste"
  7. Save the file
Programming References
C Curly Brackets {  }
    X = 1 + 1;
    Y = X + 1;
    Move(1,100);
              {X = 1 + 1; Y = X + 1;
    Move(1,100);
if (condition)
    X = 2;
Y = X + 1;
if (condition)
    X = 2;
    Y = X + 1;
C Variables
// Example to add 2 integer numbers
void Add(int a, int b)
    int c;  // declare a local integer variable
    c = a + b;  // add the integer numbers
    printf("sum = %d\n", c);  // print the sum
int c;  // declare a global integer variable
C Functions (Subroutines)
void SomeFunction(void)
Data/Motion Capture with a C Program
#define N 5000
    int i,k;
    CS0_TimeExecuted=0.0;
    while (CS0_TimeExecuted==0.0) ;	// wait till we Start
    *p++ = 0.0;
    X0 = *p++ = ch0->Dest;
    Y0 = *p++ = ch1->Dest;
    Z0 = *p++ = ch2->Dest;
    T0 = Time_sec();
    // Capture Data
    for (i=0; i<N-1; i++)
        for (k=0; k<2; k++)	WaitNextTimeSlice();                *p++ = Time_sec() - T0;        *p++ = ch0->Dest;
        *p++ = ch1->Dest;
        *p++ = ch2->Dest;
    p=gather_buffer;
    fprintf(f,"T,X,Y,Z\n");  // Header
    for (i=0; i<N; i++)
        p += 4;
M100 (Trigger Capture)
G4 P0.1 (Wait till loaded)
G0 G20 X0 Y0 Z0
F100
G1 X0 Y1
G1 X1 Y1
G1 X1 Y0
G1 X0 Y0
M2
PlotCaptureXYZwithHeader.xlsx
Global Persist Variables
persist.UserData[xxx]
    double d;
    return d;
    double d=v;
Axis Homing and Indexing
  1. Jog in some direction
  3. stop
  4. wait until fully stopped
  5. Zero
Gather Buffer
	for (;;) // loop forever
	}   // end of forever loop
#define TIME_ON 5.0 //seconds
		SetBit(OUTPUT_BIT);  //yes
		ClearBit(OUTPUT_BIT);  //no
Common C Programming Mistakes
2+2;
2;
ClearStopImmediately;
