Revision as of 11:42, 25 March 2024 by TK (Talk | contribs)
Mechsoft
Just an FYI:
Thanks for your rapid reply!
Troy
AutoDesk Fusion 360
See this post
Also this post
http://www.cnczone.com/forums/dynomotion-kflop-kanalog/343726-posprocessor-fusion360-kflop.html#post2086576
Alexander (Александр Украинец) contributed two Posts.  One for Mill and one for Lathe (the .txt extension should be removed)
Fusion_360_KFLOP_Mill.cps.txt
BobCAD
See Forum Thread here.
Dolphin CAD/CAM
