Note the App being debugged should be using the Debug Versions of the KMotion Libraries from the Debug folder rather than the Release folder. The BuildAllLibs.sln in configuration Debug may be used to create the Debug Versions.
Quote:
KMotionDLL.dll
KMotion_dotNet.dll
KMotion_dotNet_Interop.dll
GCodeInterpreter.dll
KMotionServer.exe
TCC67.exe
