Revision as of 15:31, 17 October 2019 by Sascha F Zeller (Talk | contribs)
Quote:
Set the Debug Configuration's Build output path = bin\Debug1    (This can be anything except a folder named "Debug" or "Release")
KMotionDLL.dll
KMotion_dotNet.dll
KMotion_dotNet_Interop.dll
GCodeInterpreter.dll
KMotionServer.exe
TCC67.exe
