Find and share information on Dynomotion Systems. Please feel free to contribute and correct information yourself. Joining is not required to view or search for information, however you will need to register and confirm your email account before you can edit or add pages. By default, a WYSIWYG editor is enabled to make editing pages easier. Standard MediaWiki editing may also be used or set as the default in your User Preferences. We recommend saving your work as you add pages to prevent loss of information due to potential system errors.
Creating New Wiki Pages
To create a new wiki page after registering for an account, you can first search for the name of the page you wish to create. In the results of the search, there will be a link to create that page. Click on the link and begin editing. You can then link that new page from the front page of the wiki under the appropriate heading.
Installation
Board Info
