Revision as of 17:42, 21 December 2018 by SFZ (Talk | contribs)
  5. Right Mouse Click "Paste"
  7. Save the file
Programming References
C Curly Brackets {  }
    X = 1 + 1;
    Y = X + 1;
    Move(1,100);
              {X = 1 + 1; Y = X + 1;
    Move(1,100);
if (condition)
    X = 2;
Y = X + 1;
if (condition)
    X = 2;
    Y = X + 1;
C Functions (Subroutines)
void SomeFunction(void)
Global Persist Variables
persist.UserData[xxx]
    double d;
    return d;
    double d=v;
Axis Homing and Indexing
  1. Jog in some direction
  3. stop
  4. wait until fully stopped
  5. Zero
KFLOP User C Programs are given CPU Time Slices to execute so they are guaranteed to execute on a periodic basis.  With only 1 User Thread running they are guaranteed to execute every 180us.  So any index pulse longer that this time period will never be missed.  Also with a proximity sensor the change in state will be guaranteed to be detected withing this time period.
Gather Buffer
	for (;;) // loop forever
	}   // end of forever loop
#define TIME_ON 5.0 //seconds
		SetBit(OUTPUT_BIT);  //yes
		ClearBit(OUTPUT_BIT);  //no
Common C Programming Mistakes
2+2;
2;
ClearStopImmediately;
