Revision as of 18:07, 29 November 2018 by TK (Talk | contribs)
  5. Right Mouse Click "Paste"
  7. Save the file
Programming References
1
2
3
4
5
C Curly Brackets {  }
1
2
3
4
5
    X = 1 + 1;
    Y = X + 1;
    Move(1,100);
1
2
3
              {X = 1 + 1; Y = X + 1;
    Move(1,100);
1
2
3
if (condition)
    X = 2;
Y = X + 1;
1
2
3
4
5
if (condition)
    X = 2;
    Y = X + 1;
C Functions (Subroutines)
1
2
3
4
5
6
7
    while (!CheckDone(Axis))  ;  // wait until done moving
void SomeFunction(void)
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
    while (!CheckDone(0))  ;  // wait until done moving
    while (!CheckDone(1))  ;  // wait until done moving
    while (!CheckDone(2))  ;  // wait until done moving
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
Global Persist Variables
persist.UserData[xxx]
    double d;
    return d;
    double d=v;
Axis Homing and Indexing
  1. Jog in some direction
  3. stop
  4. wait until fully stopped
  5. Zero
1
2
3
4
5
6
7
8
9
result = SimpleHomeIndexFunction(2,  // axis number to home
-1,      // direction to move toward home (+1 or -1)
138,    // limit bit number to watch for
0,      // limit polarity to wait for (1 or 0)
100.0,  // speed to move while searching for index
-1,     // index bit number to watch for (use -1 for none)
1,      // index polarity to wait for (1 or 0)
5000);  // amount to move inside limits
KFLOP User C Programs are given CPU Time Slices to execute so they are guaranteed to execute on a periodic basis.  With only 1 User Thread running they are guaranteed to execute every 180us.  So any index pulse longer that this time period will never be missed.  Also with a proximity sensor the change in state will be guaranteed to be detected withing this time period.
Gather Buffer
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
    for (;;) // loop forever
        ServiceTimerSequence();  // service the timer sequencing
    }   // end of forever loop
#define TIME_ON 5.0 //seconds
    static double T0=0.0;  // remember the last time we turned on
    if (T0==0.0 || T > T0 + CYCLE_TIME) T0=T;  // set start time of cycle
    if (T < T0 + TIME_ON)  // are we within the TIME_ON section of the cycle?
        SetBit(OUTPUT_BIT);  //yes
        ClearBit(OUTPUT_BIT);  //no
Common C Programming Mistakes
2+2;
2;
ClearStopImmediately;
Note we are working on a new code Validation tool (using splint.exe) that will analyze code, detect no useful purpose, and provide warnings in these types of cases. Look for it in the next Version 4.35.
