- 1 Initialization C Program
- 3 Programming References
- 4 Simplest C Program
- 5 C Curly Brackets { }
- 6 C Functions (Subroutines)
- 7 Basic Disk Read/Write
- 9 Global Persist Variables
- 12 Gather Buffer
- 14 Common C Programming Mistakes
void SomeFunction(void)
persist.UserData[xxx]
double d;
return d;
double d=v;
Gather Buffer
A common programming mistake is to forget to add the '()' for a function call. It might not be obvious why this isn't flagged as an error. In some programming languages such as Basic a subroutine with no parameters can be called by coding the name with no parenthesis. In C the name of a function represents the address of the function. Adding the () is required to make a function call to that address.
2+2;
2;
ClearStopImmediately;
is a valid expression. The compiler computes the address of the function ClearStopImmediately and does nothing with it.
Note we are working on a new code Validation tool (using splint.exe) that will analyze code, detect no useful purpose, and provide warnings in these types of cases. Look for it in the next Version 4.35.
