- 1 Initialization C Program
- 3 Programming References
- 4 Simplest C Program
- 5 C Curly Brackets { }
- 6 C Functions (Subroutines)
- 7 Basic Disk Read/Write
- 9 Global Persist Variables
- 12 Gather Buffer
void SomeFunction(void)
persist.UserData[xxx]
double d;
return d;
double d=v;
Gather Buffer
