- 1 Initialization C Program
- 3 Programming References
- 4 Simplest C Program
- 5 C Curly Brackets { }
- 6 C Functions (Subroutines)
- 7 Basic Disk Read/Write
- 9 Global Persist Variables
- 12 Gather Buffer
<span style="color: #000000;">#include "KMotionDef.h"</span> main() { printf("Hello World!\n"); // send message to console }
void SomeFunction(void)
include "KMotionDef.h" main() { EnableAxis(0); // enable the Axis Move(0,1000.0); // move the Axis while (!CheckDone(0)) ; // wait until done moving EnableAxis(1); // enable the Axis Move(1,2000.0); // move the Axis while (!CheckDone(1)) ; // wait until done moving EnableAxis(2); // enable the Axis Move(1,-3000.0); // move the Axis while (!CheckDone(2)) ; // wait until done moving }
include "KMotionDef.h" // define function to Enable, Move, and wait with two parameters void EnableMoveWait(int Axis, double dist) { EnableAxis(Axis); // enable the Axis Move(Axis,dist); // move the Axis while (!CheckDone(Axis)) ; // wait until done moving } main() { EnableMoveWait(0, 1000.0); // call function for Axis 0 EnableMoveWait(1, 2000.0); // call function for Axis 1 EnableMoveWait(2,-3000.0); // call function for Axis 2 }
include "KMotionDef.h" // define function prototype of function to expect later void EnableMoveWait(int Axis, double dist); main() { EnableMoveWait(0, 1000.0); // call function for Axis 0 EnableMoveWait(1, 2000.0); // call function for Axis 1 EnableMoveWait(2,-3000.0); // call function for Axis 2 } // define function to Enable, Move, and wait with two parameters void EnableMoveWait(int Axis, double dist) { EnableAxis(Axis); // enable the Axis Move(Axis,dist); // move the Axis while (!CheckDone(Axis)) ; // wait until done moving }
persist.UserData[xxx]
double d;
return d;
double d=v;
Gather Buffer
