Revision as of 13:26, 19 July 2016 by TK (Talk | contribs)
  5. Right Mouse Click "Paste"
  7. Save the file
Programming References
Global Persist Variables
persist.UserData[xxx]
    double d;
    return d;
    double d=v;
Gather Buffer
	for (;;) // loop forever
	}   // end of forever loop
#define TIME_ON 5.0 //seconds
		SetBit(OUTPUT_BIT);  //yes
		ClearBit(OUTPUT_BIT);  //no
