Revision as of 23:08, 9 March 2016 by TK (Talk | contribs)
  5. Right Mouse Click "Paste"
  7. Save the file
Programming References
Global Persist Variables
persist.UserData[xxx]
    double d;
    return d;
    double d=v;
Gather Buffer
