Revision as of 14:32, 11 February 2016 by Moray (Talk | contribs)
  5. Right Mouse Click "Paste"
  7. Save the file
Programming References
For KFlop specific references, all available variables and functions are listed in the KMotionDef.h file, located within the DSP_FLOP directory at <KMotion Installation Directory>\DSP_KFLOP. An index of the available variables and functions can be found in the KMotionDef page.
Global Persist Variables
persist.UserData[xxx]
    double d;
    return d;
    double d=v;
Gather Buffer
