BlockDiagram | Board Layout |
Kanalog Use and Settings |
Relay Drivers / Grounding
KFLOP Functional Diagram
[../Help/ConfigurationScreen/ConfigurationScreen.htm#Input_Channels Configuration Screen]
- select Axis Channel #1
Testing Analog Amplifiers
