Revision as of 12:28, 22 October 2015 by TK (Talk | contribs)
Specification
Kanalog Hardware/Connectors
BlockDiagram Board Layout
Kanalog Use and Settings
Relay Drivers / Grounding
There is a starting configuration for KFLOP+Kanalog called KanalogInitialPID.mot in the \KMotion\Motors folder.  Load it into an axis channel from the KMotion Configuration Screen.
The basic first steps are to verify the hardware:
  1. check the encoder counts correctly
  2. check that the DACs can command the Amplifier to control motor speed.  Test Console commands like DAC0=200  (with the axis disabled)
  3. Enable the Servo using the Step Response Screen.  Zero, Enable
Testing Analog Amplifiers
