Revision as of 00:28, 19 October 2015 by BradG (Talk | contribs)
  • Choose a descriptive page name and link text when creating a new page: e.g. Not "My Machine", but rather "Three Axis Milling Machine Retrofit"
  • Compiling KMotionCNC
  • Troy (tmday7) created some helpful documents listed on the Yahoo Group Files Section here.
