Unintuitively, you first create a link to the page you want to make before you can make the page. While editing, right-click where you want your link to be, insert a link with a descriptive title and link text, save the page, click on the link you created, then click on "Empty Page" to begin editing your new page.
- Choose a descriptive page name and link text when creating a new page: e.g. Not "My Machine", but rather "Three Axis Milling Machine Retrofit"
