Revision as of 23:11, 18 October 2015 by BradG (Talk | contribs)
To create a new wiki page (after registering for an account) click 'edit' on the page or section from where you want your page linked, scroll to where you want to insert the link to your page, insert a link, save the page, click on the link you created, then click on "Empty Page" to begin editing.
  • Choose a descriptive page name and link text when creating a new page: e.g. Not "My Machine", but rather "Three Axis Milling Machine Retrofit"
  • Compiling KMotionCNC
  • Troy (tmday7) created some helpful documents listed on the Yahoo Group Files Section here.
