Revision as of 23:05, 18 October 2015 by BradG (Talk | contribs)
Creating New Wiki Pages
To create a new wiki page (after registering for an account) click 'edit' on this main page, scroll to where you want to insert the link to your page, insert a link, save the page, click on the link you created, then click on "Empty Page" to begin editing.
  • Choose a descriptive page name and link text when creating a new page: e.g. Not "My Machine", but rather "Three Axis Milling Machine Retrofit"
  • Compiling KMotionCNC
  • Troy (tmday7) created some helpful documents listed on the Yahoo Group Files Section here.
