Revision as of 20:37, 18 October 2015 by BradG (Talk | contribs)
Creating New Wiki Pages
- Full release download page
How to update KFLOP Firmware - whenever a new version of software is installed, the firmware within KFLOP must be updated to match the new version
- Screens
- Screens
- Homing discussion
The KMotionCNC's Visual Studio Project Solution (\PC VC Programs\KMotionCNC\KMotionCNC.sln) is currently written for Visual Studio 2008 Standard.  This version can be used for the simplest compatibility.  Projects can be upgraded to newer version of VS with minimal effort.  Including Microsoft's Free Visual Studio 2013 Community.
Updating KFLOP Firmware
The error:
  1. Run KMotion.exe
You may enter the "Version" command on the KMotion Console Screen to verify that the Version of firmware running in KFLOP now matches the Version of software installed on the PC.  To check the Version of Software running on the PC select Help | About in KMotion or Right click the Title bar in KMotionCNC and select About KMotionCNC.
  5. Right Mouse Click "Paste"
  7. Save the file
