- 2 Creating New Wiki Pages
- 5 Problems and Resolutions
- 6 Applications and Projects
- 9 Software Test Releases
- 10 PC Example Applications
- 11 KFLOP C Programs
- 12 Wiring Diagrams
- Screens
- Screens
- Homing discussion
Customize KmotionCNC
Updating KFLOP Firmware
The error:
- Run KMotion.exe
You may enter the "Version" command on the KMotion Console Screen to verify that the Version of firmware running in KFLOP now matches the Version of software installed on the PC. To check the Version of Software running on the PC select Help | About in KMotion or Right click the Title bar in KMotionCNC and select About KMotionCNC.
