Revision as of 20:09, 18 October 2015 by BradG (Talk | contribs)
Creating New Wiki Pages
  • Right-Click with the mouse is a shortcut to insert Links or images.
  • For Spell Correction use Ctrl-Right-Click.
- Full release download page
- Screens
- Screens
- Homing discussion
Customize KmotionCNC
The KMotionCNC's Visual Studio Project Solution (\PC VC Programs is currently written for Visual Studio 2008 Standard.  This version can be used for the simplest compatibility.  Projects can be upgraded to newer version of VS with minimal effort.  Including Microsoft's Free Visual Studio 2013 Community.
Links to examples of projects that explain how you created your own KMotionCNC customizations
- Link to example 1
Updating KFLOP Firmware
The error:
  1. Run KMotion.exe
  5. Right Mouse Click "Paste"
  7. Save the file
