Welcome to our wiki where you can find and share knowledge on Dynomotion's systems.  To begin adding information to this wiki, simply create an account, verify your email, and start editing. To make editing pages easier for everyone, we have installed a visual editor by default.  This visual editor allows you to edit a wiki page much like you would a standard word processing document.  Note that Right-Clicking with the mouse is a shortcut  to insert Links or images.  For Spell Correction use Ctrl-Right-Click.  Standard MediaWiki editing may also be used using the symbol on edit the tool bar or set as the default in your User Preferences.  To insert a YouTube Video it is required to use an EmbedVideo command such as  {{#ev:youtube|xxxxxx}} with xxxxxx changed to the Video ID.
Creating New Wiki Pages
Updating KFLOP Firmware
The error:
  1. Run KMotion.exe
V4.33q
  5. Right Mouse Click "Paste"
  7. Save the file
View edit history of this page.
