totally overwhelmed! start over info
turbothis
Post by turbothis » Sun Mar 24, 2019 4:49 pm
after hours of trying to get anything going i have the thought of starting fresh with some questions
i have no idea where to start but need to get my head straight ......
1 i save my servo .c file on desktop and have my user button set to this
i do this to separate it from the rest for my sanity.
is this bad and it must be in the in the C programs section of kmotion? or is it fine?
2 i am very confused on the kflop config and downloading thing.
if i have a .c file i made on the desktop and a user button to it, will it run that or does it need to be downloaded to kflop first or every time
edited???
3 if i download a bunch of dead and nonfunctional C programs will they stack up and conflict new more productive programs when downloaded?
i feel like there is a ton of stuff happening behind the curtain if you know what i mean
4 how do i know what all is downloaded on the kflop?
5 i think there used to be a youtube video on the process of downloading and such?
Re: totally overwhelmed! start over info
Post by TomKerekes » Sun Mar 24, 2019 5:32 pm
Hi turbothis,
It is fine.
edited???
Pushing the User Button will compile the program, download the program to the specified Thread (killing and overwriting any previous program in that Thread), and execute the Program.
No Programs don't "stack up". Each Thread Space can hold one Program at a time. Downloading a Program to a Thread will completely overwrite any previous program.
However running a bad/buggy/unknown C Program can modify or corrupt KFLOP in an indeterminate manner. If you suspect you have modified or corrupted KFLOP then re-boot KFLOP to assure it is in a virgin default state.
You must keep track of what you are doing. Re-boot KFLOP to assure it is in a virgin default state. We do not recommend flashing configuration or Programs to KFLOP. If you have done this KFLOP can be set back to its default state by re-Flashing "New Version".
You might see this article.
turbothis
Post by turbothis » Sun Mar 24, 2019 6:41 pm
great
thanks
so i run the phase find and get some info on the A axis servo
2048 encoder 6 pole motor
should be 0.000366 right?
REPORT
0 Position = 8192 PhaseAngle = 3.520000
1 Position = 16384 PhaseAngle = 6.518000
2 Position = 16384 PhaseAngle = 6.404000
3 Position = 0 PhaseAngle = 0.382000
Counts per rev = 8192
Counts per cycle = 2732
Counts per cycle (rounded to 16)= 2736
invDistPerCycle (rounded)= 0.000365497076
Commutation offset = 1945
Input Gain Specified = -1.000
REPORT
0 Position = -2 PhaseAngle = 0.492000
1 Position = 8191 PhaseAngle = 3.519000
2 Position = 8191 PhaseAngle = 3.404000
3 Position = -1 PhaseAngle = 0.380000
Counts per rev = 8193
Counts per cycle = 2707
Counts per cycle (rounded to 16)= 2704
invDistPerCycle (rounded)= 0.000369822485
Commutation offset = 1924
REPORT
0 Position = 0 PhaseAngle = 0.491000
1 Position = 8192 PhaseAngle = 3.519000
2 Position = 8192 PhaseAngle = 3.404000
3 Position = -8192 PhaseAngle = -2.615000
Counts per cycle = 2705
REPORT
0 Position = 8192 PhaseAngle = 3.518000
1 Position = 16384 PhaseAngle = 6.519000
2 Position = 0 PhaseAngle = 0.382000
3 Position = -8192 PhaseAngle = -2.613000
Counts per cycle = 2730
Commutation offset = 1917
REPORT
2 Position = 16384 PhaseAngle = 6.405000
3 Position = -1 PhaseAngle = 0.381000
Commutation offset = 1948
// Drive a 3 Phase motor that has a Z index by
// 3 phase driving the coils (like a stepping motor)
// two revs each direction (two z pulses)
// monitor how many counts/cycle and counts/rev
// (including direction)and also determine the commutation
// offset by recording the phase angle at the index
// (which will be where zero is set) and offsetting by 1/4 of a cycle
// Set the following parameters according to your situation
// See the report generated on the Console Screen
#define DAC_CHAN 0      // which pair of PWM channels used
#define ENCODER_CHAN 1  // which encoder we are connected to
#define ENCODER_GAIN -1  // Set to -1 if desired to reverse axis direction
#define AMPLITUDE 100   // Set how hard to drive the coils pwm counts
#define Z_BIT_NUMBER 36  // What bit the Z index is connected to
#define AXIS_CHAN 0     // Axis channel to be used and configured
#define Ncycles 4       // don't change this
void Write3PH_DACs(CHAN *ch0, float v, double angle_in_cycles);
float fractionf(double v);
	float mid,k=0,dk=0.2,A=AMPLITUDE;   // set coil current amplitude
	int i,ignore=300,kpos[Ncycles],zmark,m=0;
	double cnts_per_cycle,p0[Ncycles];
	CHAN *ch = &chan[AXIS_CHAN];
	ch->Enable=FALSE;
	ch->InputMode=ENCODER_MODE;
	ch->InputChan0=ENCODER_CHAN;
	ch->OutputChan0=DAC_CHAN;
	ch->OutputChan1=DAC_CHAN+1;
	ch->OutputMode=NO_OUTPUT_MODE;
	ch->InputGain0=ENCODER_GAIN;
	for (;;)
		WaitNextTimeSlice();
		k+= dk;
		Write3PH_DACs(ch,A, k/1000.0);  // move the pole
		zmark = ReadBit(Z_BIT_NUMBER);
		if (!zmark && ignore>0) ignore--;
		if (ignore==0 && zmark)  // check for index mark
			p0[m]=ch->Position;  // save position
			kpos[m]=k;           // save phase angle
			if (++m == Ncycles)
				ch->Position=0;  // set current position to Zero
				break;
			if (m==2) dk = -dk;
			ignore=300;
	Write3PH_DACs(ch,0,0);    // turn off the coil
	printf("\nREPORT\n------\n");
	for (i=0; i<Ncycles; i++)
		printf("%d Position = %6.0f PhaseAngle = %f\n",i,p0[i],kpos[i]/1000.0);
	printf("Counts per rev = %6.0f\n",p0[1]-p0[0]);
	cnts_per_cycle = (p0[1]-p0[0])/(kpos[1]-kpos[0])*1000.0;
	printf("Counts per cycle = %6.0f\n",cnts_per_cycle);
	// round to 16
	if (cnts_per_cycle>0)
		cnts_per_cycle = ((int)(cnts_per_cycle/16.0 + 0.5))*16.0;
		cnts_per_cycle = ((int)(cnts_per_cycle/16.0 - 0.5))*16.0;
	printf("Counts per cycle (rounded to 16)= %6.0f\n",cnts_per_cycle);
	ch->invDistPerCycle = 1.0/cnts_per_cycle;
	printf("invDistPerCycle (rounded)= %15.12f\n",ch->invDistPerCycle);
	mid = (kpos[2]+kpos[1])/2000.0;
	mid = mid - (int)mid;
	ch->CommutationOffset = mid*cnts_per_cycle + 0.25*fast_fabs(cnts_per_cycle);
	printf("Commutation offset = %6.0f\n",ch->CommutationOffset);
	printf("Input Gain Specified = %6.3f\n",ch->InputGain0);
void Write3PH_DACs(CHAN *ch, float v, double angle_in_cycles)
	float theta,sin1f;
	if (angle_in_cycles<0)
	DAC(ch->OutputChan0, (int)(v * Sine3PH(theta,&sin1f)));
	DAC(ch->OutputChan1, (int)(v * sin1f));
i do not know why but i cant get a Z index to work on any bits but 36
40, 44 and 48 should be Z+ right? followed by Z-
turbothis
Post by turbothis » Sun Mar 24, 2019 8:18 pm
not sure what the "-nan (ind)" means
i have my X axis code working fine in basic lathe 2 axis mode. when i switch to the basic 4 axis mode (so i can have A axis spindle) now the Z buttons run the X axis motor and read out.
mentally fatiguing
Post by TomKerekes » Sun Mar 24, 2019 9:39 pm
Hi turbothis,
The exact number would be:
3 / (2048 x 4) = 0.0003662109375
Its important to enter the exact number otherwise after many many revolutions the commutation will drift off.
I don't understand what you are doing or asking.
nan = "not a number" which is caused by a division by zero. Earlier we asked you to not set any Axis resolution to 0 count/inch. It appears you failed to this.
Selecting Lathe mode in the Tool Setup - Trajectory Planner should only be used with the Basic Lathe 2 Axis Main Dialog Face. For your special (3 Axis XZA?) Lathe configuration you will need to create a custom Screen with the Screen Editor.
turbothis
Post by turbothis » Tue Mar 26, 2019 4:28 pm
i have all the axis parameters set and still get the "nan"
all the Z index encoder inputs for the axis are bit 36, 40, 44, and 48 right?
i can only get bit 36 to read a Z index pulse
thanks
Post by TomKerekes » Tue Mar 26, 2019 8:19 pm
Hi turbothis,
Please post a screen shot of your KMotionCNC | Tool Setup | Trajectory Planner settings so we can check them for you.
There aren't any dedicated Z index inputs. Any KFLOP input can be used as long as it is interfaced and configured properly. You would need to inform us input you are using. Please put more effort into your questions. Normally for differential encoder Z signals they can be connected to the 8 differential inputs on Kanalog JP2 which normally map to KFLOP IO36-43 respectively. It isn't clear why you are incrementing by 4.
turbothis
Post by turbothis » Tue Mar 26, 2019 9:06 pm
i was thinking the JP2 inputs where a group of 4 bits per channel. like the JP1 encoder inputs. after all it is labelled the same. i.e A4+ A4- B4+ B4-..........
turbothis
Post by turbothis » Tue Mar 26, 2019 9:38 pm
this is the code i am testing and cant get a Z index on bit 40?
// Home and set the commutation for a 3 phase brushless motor
// that is driven using two DAC Outputs
// Phase rotates until index mark is located and Encoder Zeroed
// Function definitions
void Write3PH_DACs(CHAN *ch2, float v, double angle_in_cycles);
	float k=0,A=200;   // set coil current amplitude DAC units
	double p0;
	// define the axis as 3 phase BRUSHLESS_3PH_MODE
	ch2->InputMode=ENCODER_MODE;
	ch2->OutputMode=NO_OUTPUT_MODE;
	ch2->Vel=500;
	ch2->Accel=50000;
	ch2->Jerk=300000;
	ch2->P=1;
	ch2->I=0;
	ch2->D=0;
	ch2->FFAccel=0;
	ch2->FFVel=0;
	ch2->MaxI=200;
	ch2->MaxErr=1e+006;
	ch2->MaxOutput=500;
	ch2->DeadBandGain=1;
	ch2->DeadBandRange=0;
	ch2->InputChan0=2;
	ch2->InputChan1=2;
	ch2->OutputChan0=0;
	ch2->OutputChan1=1;
	ch2->MasterAxis=-1;
	ch2->LimitSwitchOptions=0x0;
	ch2->SoftLimitPos=1e+030;
	ch2->SoftLimitNeg=-1e+030;
	ch2->InputGain0=-1;
	ch2->InputGain1=1;
	ch2->InputOffset0=0;
	ch2->InputOffset1=0;
	ch2->OutputGain=1;
	ch2->OutputOffset=0;
	ch2->SlaveGain=1;
	ch2->BacklashAmount=0;
	ch2->BacklashRate=0;
	ch2->invDistPerCycle=0.0003662109375;
	ch2->Lead=0;
	ch2->StepperAmplitude=20;
	ch2->iir[0].B0=1;
	ch2->iir[0].B1=0;
	ch2->iir[0].B2=0;
	ch2->iir[0].A1=0;
	ch2->iir[0].A2=0;
	ch2->iir[1].B0=1;
	ch2->iir[1].B1=0;
	ch2->iir[1].B2=0;
	ch2->iir[1].A1=0;
	ch2->iir[1].A2=0;
	ch2->iir[2].B0=1;
	ch2->iir[2].B1=0;
	ch2->iir[2].B2=0;
	ch2->iir[2].A1=0;
	ch2->iir[2].A2=0;
	ch2->Enable=FALSE;
	for (;;)
		Write3PH_DACs(ch2,A, ++k/1000.0);  // move the pole
		if (ReadBit(40))  // check for index mark
			p0=ch2->Position; // save position
			ch2->Position=0;  // set current position to Zero
			ch2->CommutationOffset = 1920;  // from auto phase find
			printf("Position = %f\n",p0);
			break;
        EnableAxisDest(2,0.0f);  // Enable servo at destination of 0
	DefineCoordSystem(0,-1,1,2); // define which axes are in use
	// Loop forever outputting Servo output to dual DAC_SERVO_MODE
	for (;;)
		CHAN *ch=ch2;
		if (ch->Enable)  // if axis enabled commutate and output else command zero to DACs
			Write3PH_DACs(ch, ch->Output, (ch->Position + ch->CommutationOffset) * ch->invDistPerCycle);
			Write3PH_DACs(ch, 0.0, 0.0);
	float theta,sin1f;
if i change it to bit 36 and wire the Z to this then it works
turbothis
Post by turbothis » Tue Mar 26, 2019 9:45 pm
when i program A axis to use ch0-1 outputs and bit 36 Z index i still get the nan ind and seems to get a good amount of noise on the input. like on the Feed slide bar goes up and down
this is with no movement of the A axis servo (it wont move just holds pos)
