hello,
now i want to make a plasma cutting machine. what products from dynomotion should I buy? certainly KFLOP and there are other additions.
Re: plasma cutting machine
I need 3 axis, X Y Z. plan X and Y using stepper motor Nema 34, and Y I'm not so sure, what's your suggestion for Z axis about motor? do they all have to be the same? then what board should I buy?
If you obtain Step/Direction Motor Drivers those can usually be driven directly by KFLOP.
If you need to input analog voltages such as Torch Voltage you might add Kanalog.
If you need more isolated IO you might add one or more Konnects.
Motors don't need to be the same.
is there an update for the kmotionCNC software, sir?
