plasma cutting machine
irmad
Post by irmad » Thu Jan 20, 2022 8:14 am
hello,
now i want to make a plasma cutting machine. what products from dynomotion should I buy? certainly KFLOP and there are other additions.
Re: plasma cutting machine
Post by TomKerekes » Thu Jan 20, 2022 5:17 pm
That would depend on your design.
irmad
Post by irmad » Sat Jan 22, 2022 9:34 am
I need 3 axis, X Y Z. plan X and Y using stepper motor Nema 34, and Y I'm not so sure, what's your suggestion for Z axis about motor? do they all have to be the same? then what board should I buy?
Post by TomKerekes » Sat Jan 22, 2022 5:19 pm
If you obtain Step/Direction Motor Drivers those can usually be driven directly by KFLOP.
If you need to input analog voltages such as Torch Voltage you might add Kanalog.
If you need more isolated IO you might add one or more Konnects.
Motors don't need to be the same.
irmad
Post by irmad » Tue Apr 12, 2022 7:53 am
is there an update for the kmotionCNC software, sir?
Post by TomKerekes » Tue Apr 12, 2022 5:12 pm
Latest Test Release is 4.35f
