- 1 Initialization C Program
- 3 Programming References
- 4 Simplest C Program
- 5 C Curly Brackets { }
- 6 C Functions (Subroutines)
- 7 Basic Disk Read/Write
- 9 Global Persist Variables
- 12 Axis Homing and Indexing
- 13 Gather Buffer
- 14 Performing multiple Operations continually in a forever Loop
- 15 Common C Programming Mistakes
X = 1 + 1;
Y = X + 1;
Move(1,100);
{X = 1 + 1; Y = X + 1;
Move(1,100);
if (condition)
X = 2;
Y = X + 1;
if (condition)
X = 2;
Y = X + 1;
void SomeFunction(void)
persist.UserData[xxx]
double d;
return d;
double d=v;
- Jog in some direction
- wait for an input to change
- stop
- wait until fully stopped
- Zero
result = SimpleHomeIndexFunction(2, // axis number to home
1000.0, // speed to move toward home
-1, // direction to move toward home (+1 or -1)
Note that because homing is all performed in software any IO bits can be used. Some of the documentation lists IO bits to be used but these are only suggestions.
Index pulses from encoders are typically differential signals. The differential index pulse signal can be connected to any unused A or B differential input. Or one of the + or - differential signals can be connected to a single ended digital input. Note that KFLOP's 3.3V inputs should not be driven hard (> 10ma) above 3.8V. Most 5V differential drivers do not do this.
KFLOP User C Programs are given CPU Time Slices to execute so they are guaranteed to execute on a periodic basis. With only 1 User Thread running they are guaranteed to execute every 180us. So any index pulse longer that this time period will never be missed. Also with a proximity sensor the change in state will be guaranteed to be detected withing this time period.
Gather Buffer
for (;;) // loop forever
} // end of forever loop
#define TIME_ON 5.0 //seconds
SetBit(OUTPUT_BIT); //yes
ClearBit(OUTPUT_BIT); //no
A common programming mistake is to forget to add the '()' for a function call. It might not be obvious why this isn't flagged as an error. In some programming languages such as Basic a subroutine with no parameters can be called by coding the name with no parenthesis. In C the name of a function represents the address of the function. Adding the () is required to make a function call to that address.
2+2;
2;
ClearStopImmediately;
is a valid expression. The compiler computes the address of the function ClearStopImmediately and does nothing with it.
