- 1 Initialization C Program
- 3 Programming References
- 4 Simplest C Program
- 5 C Curly Brackets { }
- 6 C Functions (Subroutines)
- 7 Basic Disk Read/Write
- 9 Global Persist Variables
- 12 Gather Buffer
X = 1 + 1;
Y = X + 1;
Move(1,100);
{X = 1 + 1; Y = X + 1;
Move(1,100);
if (condition)
X = 2;
Y = X + 1;
if (condition)
X = 2;
Y = X + 1;
void SomeFunction(void)
persist.UserData[xxx]
double d;
return d;
double d=v;
Gather Buffer
for (;;) // loop forever
} // end of forever loop
#define TIME_ON 5.0 //seconds
SetBit(OUTPUT_BIT); //yes
ClearBit(OUTPUT_BIT); //no
