Changes
=='''Dynomotion wiki '''<span style="color: #999999;">(started 10/12/2015)'''<br />'''</span>==
Welcome to our wiki where you can find and share knowledge on Dynomotion's systems. To begin adding information to this wiki, simply create an account and start editing. To make editing pages easier for everyone, we have installed a [https://help.bluespice.com/index.php/VisualEditor visual editor] by default. This visual editor allows you to edit a wiki page much like you would a standard word processing document. Note that Right-Clicking with the mouse is a shortcut way to insert Links or images. For Spell Correction Ctrl-Right-Click may be used. Standard [https://www.mediawiki.org/wiki/Help:Editing MediaWiki editing] may also be used or set as the default in your User PreferencesPreferences or switched to using the [[]] symbol on the tool bar.
''Warning: Use at your own risk. Information is for example purposes only and may contain errors. It is up to the User to verify the information is correct and is safe to use. In no case will any contributor or Dynomotion be liable for incorrect information.''
