- 1 Introduction
- 8 Main Screen Style
- 10 Control styles
- 11 Control attributes
- 12 Control Script Options
- 13 Main Window attributes
- 19 Axis DRO Number Formats
- Show/Hide Controls
- Change Label/Button Text
- Change Font/Text Size
- Bitmap Buttons and Labels
- JPG, BMP, PNG Bitmaps
- Toggle Bitmap Labels (LEDs)
- Custom User Entry Controls
https://www.youtube.com/watch?v=Pp5DPfn8GLI
Main Screen Style
- Label
- Momentary button
- DualLabel
- Select ID
Using this field, the user has three options shown below.
- Show/Hide
- Move/Resize
- Main Dialog Screen
- Script File
Motion Buttons (Jog Buttons) allow individually, forced disable/enable via setting the Screen Script Var parameter to 0=Force Disable, 1=Force Enable, -1=dynamic automatic behavior based on Job Running or not.
To Scale a Screen:
- Select mode: Screen Scale
Example Original Screen:
Example Scaled up 60%
When creating multiple Screens with sections of Controls that are duplicated among screens, possibly re-positioned on the Screen, it is useful to make use of SubScript files. Selecting one or more Controls and setting a SubScript file name for them will move them to a separate file which will then be referenced from the main file. SubScript files can also reference SubScript files in a hierarchical manner.
See this Video Demonstration
Axis DRO number formats may now be specified as the Text Parameter in the Screen Editor. If Text is specified, then it is treated as DRO format of number to be displayed. Include any axis characters if desired. If different formats for Inches and mm are desired specify both separated them with ; // e.g. X:%10.4f;X:%10.3f
