Revision as of 12:49, 19 July 2023 by TK (Talk | contribs)
Advantages of Kinematics and Rotation Tool Center Point (RTCP)
G0 B0  (start at angle 0)
G1 B90 (rotate B 90 degrees).
Overview
	if (f)
		char s[81];
		fgets(s, 80, f);
#include "Kinematics.h"
#include "Kinematics3Rod.h"
#include "Kinematics5AxisTableBC.h"
Kinematics3Rod
#include "stdafx.h"
#define sqr(x) ((x)*(x))
// Construction/Destruction
	Act0Center.x = 12;
	Act0Center.y = 0;
	Act0Center.z = 0;
	Act1Center.x = 0;
	Act1Center.y = 12;
	Act1Center.z = 0;
	Act2Center.x = 11;
	Act2Center.y = 3;
	Act2Center.z = 12;
	GeoCorrect(x,y,z,&x,&y,&z);
	return 0;
Formulas to calculate Actuator Positions from XYZABC CAD Position uses Rotate3 function to rotate a point through 3 angles.
int CKinematicsGeppettoExtrude::TransformCADtoActuators(double x, double y, double z, double a, double b, double c, double *Acts, bool NoGeo)
	double x_0,y_0,z_0,x_1,y_1,z_1,x_2,y_2,z_2,x_3,y_3,z_3,x_4,y_4,z_4,x_5,y_5,z_5, TCP_Rotated_x,TCP_Rotated_y,TCP_Rotated_z;
	// Determine where the TCP rotated point would be relative to origin when oriented at the desired angles.
	Rotate3(0, 0, 0, m_MotionParams.TCP_X, m_MotionParams.TCP_Y, m_MotionParams.TCP_Z, a, b, c, &TCP_Rotated_x, &TCP_Rotated_y, &TCP_Rotated_z);
	// Translate from TCP to end effector origin
	x += TCP_Rotated_x - m_MotionParams.TCP_X;
	y += TCP_Rotated_y - m_MotionParams.TCP_Y;
	z += TCP_Rotated_z - m_MotionParams.TCP_Z;
	if (!NoGeo) GeoCorrect(x,y,z,a,b,c,&x,&y, &z, &a, &b, &c);
	// Find where connection points should be
	Rotate3(x,y,z,x+X0,y+Y0,z+Z0,a,b,c,&x_0,&y_0,&z_0);
	Rotate3(x,y,z,x+X1,y+Y1,z+Z1,a,b,c,&x_1,&y_1,&z_1);
	Rotate3(x,y,z,x+X2,y+Y2,z+Z2,a,b,c,&x_2,&y_2,&z_2);
	Rotate3(x,y,z,x+X3,y+Y3,z+Z3,a,b,c,&x_3,&y_3,&z_3);
	Rotate3(x,y,z,x+X4,y+Y4,z+Z4,a,b,c,&x_4,&y_4,&z_4);
	Rotate3(x,y,z,x+X5,y+Y5,z+Z5,a,b,c,&x_5,&y_5,&z_5);
	double r0 = sqrt(sqr(x_0 - Act0Center.x) + sqr(y_0 - Act0Center.y) + sqr(z_0 - Act0Center.z)) - Act0Off;
	double r1 = sqrt(sqr(x_1 - Act1Center.x) + sqr(y_1 - Act1Center.y) + sqr(z_1 - Act1Center.z)) - Act1Off;
	double r2 = sqrt(sqr(x_2 - Act2Center.x) + sqr(y_2 - Act2Center.y) + sqr(z_2 - Act2Center.z)) - Act2Off;
	double r3 = sqrt(sqr(x_3 - Act3Center.x) + sqr(y_3 - Act3Center.y) + sqr(z_3 - Act3Center.z)) - Act3Off;
	double r4 = sqrt(sqr(x_4 - Act4Center.x) + sqr(y_4 - Act4Center.y) + sqr(z_4 - Act4Center.z)) - Act4Off;
	double r5 = sqrt(sqr(x_5 - Act5Center.x) + sqr(y_5 - Act5Center.y) + sqr(z_5 - Act5Center.z)) - Act5Off;
	Acts[3] = r3*m_MotionParams.CountsPerInchA;
	Acts[4] = r4*m_MotionParams.CountsPerInchB;
	Acts[5] = r5*m_MotionParams.CountsPerInchC;
	return 0;
Alex's system with a Table A axis and Gimbal B axis (Kinematics5AxisTableAGimbalB.cpp)
Origin Definition
The Solution
The formula in C++ code:
		x = Xa + ToolXR + ChuckXR;
		y = Ya;
	return 0;
Scara Robot Kinematics by Demondor
Geometry below
Class name CKinematicsScara
2 Axis Spray Robot by Scott Little
Simulation
Forum Thread here.
3 Axis Cable Delta Robot by Александр Украинец
Project Details
Shared Project Files
