- 2 Overview
- 3 Kinematics3Rod
G0 B0 (start at angle 0)
G1 B90 (rotate B 90 degrees).
Overview
Kinematics3Rod
// Kinematics3Rod.cpp: implementation of the CKinematics3Rod class. // ////////////////////////////////////////////////////////////////////// #include "stdafx.h" #include "Kinematics3Rod.h" #define sqr(x) ((x)*(x)) ////////////////////////////////////////////////////////////////////// // Construction/Destruction ////////////////////////////////////////////////////////////////////// CKinematics3Rod::CKinematics3Rod() { Act0Center.x = 12; Act0Center.y = 0; Act0Center.z = 0; Act1Center.x = 0; Act1Center.y = 12; Act1Center.z = 0; Act2Center.x = 11; Act2Center.y = 3; Act2Center.z = 12; // when actuator position is zero this is how long the rod is Act0Off = sqrt(sqr(Act0Center.x) + sqr(Act0Center.y) + sqr(Act0Center.z)); Act1Off = sqrt(sqr(Act1Center.x) + sqr(Act1Center.y) + sqr(Act1Center.z)); Act2Off = sqrt(sqr(Act2Center.x) + sqr(Act2Center.y) + sqr(Act2Center.z)); m_MotionParams.MaxLinearLength = 0.25; // limit the segment lengs for nonlinear systems m_MotionParams.MaxRapidFRO = 1.0; // limit the increase in Rapid HW FRO m_MotionParams.UseOnlyLinearSegments=true; } CKinematics3Rod::~CKinematics3Rod() { } int CKinematics3Rod::TransformCADtoActuators(double x, double y, double z, double a, double b, double c, double *Acts, bool NoGeo) { // find lengths of each actuator GeoCorrect(x,y,z,&x,&y,&z); double r0 = sqrt(sqr(x-Act0Center.x) + sqr(y-Act0Center.y) + sqr(z-Act0Center.z)) - Act0Off; double r1 = sqrt(sqr(x-Act1Center.x) + sqr(y-Act1Center.y) + sqr(z-Act1Center.z)) - Act1Off; double r2 = sqrt(sqr(x-Act2Center.x) + sqr(y-Act2Center.y) + sqr(z-Act2Center.z)) - Act2Off; Acts[0] = r0*m_MotionParams.CountsPerInchX; Acts[1] = r1*m_MotionParams.CountsPerInchY; Acts[2] = r2*m_MotionParams.CountsPerInchZ; Acts[3] = a*m_MotionParams.CountsPerInchA; Acts[4] = b*m_MotionParams.CountsPerInchB; Acts[5] = c*m_MotionParams.CountsPerInchC; return 0; } // perform Inversion to go the other way int CKinematics3Rod::TransformActuatorstoCAD(double *Acts, double *xr, double *yr, double *zr, double *ar, double *br, double *cr, bool NoGeo) { return InvertTransformCADtoActuators(Acts, xr, yr, zr, ar, br, cr); }
Origin Definition
The Solution
The formula in C++ code:
// Kienematics for Table with A Axis and Tool Gimble head with B Axis // // A axis always rotates about X axis // B axis always rotates about Y axis int CKinematics5AxisTableAGimbalB::TransformCADtoActuators(double x, double y, double z, double a, double b, double c, double *Acts, bool NoGeo) { double Xt, Yt, Zt, Xa, Ya, Za, ToolXR, ToolZR, ChuckXR, ChuckZR, Dummy; if (m_MotionParams.TCP_Active) { //Find CAD Tool Tip Location from coordinate passed in (Xt, Yt, Zt) Xt = x - m_MotionParams.TCP_X; // remove tool offset Yt = y - m_MotionParams.TCP_Y; Zt = z - m_MotionParams.TCP_Z; //Perform A rotation to obtain (Xa, Ya, Za) Rotate3(0, 0, 0, Xt, Yt, Zt, a, 0, 0, &Xa, &Ya, &Za); //Determine ChuckXR ChuckZR by rotating PivotChuckLength by Angle B Rotate3(0, 0, 0, 0, 0, PivotToChuckLength, 0, -b, 0, &ChuckXR, &Dummy, &ChuckZR); //Determine Rotated Tool offset ToolXR ToolZR by rotating ToolX ToolZ by Angle B Rotate3(0, 0, 0, m_MotionParams.TCP_X, m_MotionParams.TCP_Y, m_MotionParams.TCP_Z, 0, -b, 0, &ToolXR, &Dummy, &ToolZR); x = Xa + ToolXR + ChuckXR; y = Ya; z = Za + ToolZR + ChuckZR - PivotToChuckLength; } if (!NoGeo) GeoCorrect(x,y,z,&x,&y, &z); Acts[0] = x*m_MotionParams.CountsPerInchX; Acts[1] = y*m_MotionParams.CountsPerInchY; Acts[2] = z*m_MotionParams.CountsPerInchZ; Acts[3] = a*m_MotionParams.CountsPerInchA; Acts[4] = b*m_MotionParams.CountsPerInchB; Acts[5] = c*m_MotionParams.CountsPerInchC; return 0; }
Geometry below
Class name CKinematicsScara
Simulation
Forum Thread here.
