Revision as of 14:00, 5 September 2019 by TK (Talk | contribs)
Advantages of Kinematics and Rotation Tool Center Point (RTCP)
G0 B0  (start at angle 0)
G1 B90 (rotate B 90 degrees).
Overview
	if (f)
		char s[81];
		fgets(s, 80, f);
#include "Kinematics.h"
#include "Kinematics3Rod.h"
#include "Kinematics5AxisTableBC.h"
Kinematics3Rod
#include "stdafx.h"
#define sqr(x) ((x)*(x))
// Construction/Destruction
	Act0Center.x = 12;
	Act0Center.y = 0;
	Act0Center.z = 0;
	Act1Center.x = 0;
	Act1Center.y = 12;
	Act1Center.z = 0;
	Act2Center.x = 11;
	Act2Center.y = 3;
	Act2Center.z = 12;
	GeoCorrect(x,y,z,&x,&y,&z);
	return 0;
Alex's system with a Table A axis and Gimbal B axis (Kinematics5AxisTableAGimbalB.cpp)
Origin Definition
The Solution
The formula in C++ code:
		x = Xa + ToolXR + ChuckXR;
		y = Ya;
	return 0;
