[hide]- 1 Introduction
- 5 Maximized Captionless KMotionCNC Screens
- 6 Control styles
- 7 Control attributes
- 8 Main Window attributes
- 9 Bitmap types, Alpha, and locations
- 10 Motion Buttons (for Jogging)
- 11 Performing an action Immediately within Screen Script
- 12 Scaling an Entire Screen or Portion of a Screen
- Show/Hide Controls
- Change Label/Button Text
- Change Font/Text Size
- Bitmap Buttons and Labels
- JPG, BMP, PNG Bitmaps
- Toggle Bitmap Labels (LEDs)
- Custom User Entry Controls
- Label
- Momentary button
- DualLabel
- Select ID
- Show/Hide
- Move/Resize
- Main Dialog Screen
- Script File
To Scale a Screen:
- Select mode: Screen Scale
Example Original Screen:
Example Scaled up 60%
