- Show/Hide Controls
- Change Label/Button Text
- Change Font/Text Size
- Bitmap Buttons and Labels
- JPG, BMP, PNG Bitmaps
- Toggle Bitmap Labels (LEDs)
- Custom User Entry Controls
- Label
- Momentary button
- DualLabel
- Select ID
- Show/Hide
- Move/Resize
Main Window attributes
- Main Dialog Screen
- Script File
Motion Buttons (for Jogging)
To Scale a Screen:
- Select mode: Screen Scale
Example Original Screen:
Example Scaled up 60%
