Revision as of 10:42, 1 November 2018 by TK (Talk | contribs)
  • SimpleConsole - simple example to send [../Help/CmdsCategory.htm Console Script commands] to KFLOP
Quote:
Set the Debug Configuration's Build output path = bin\Debug1    (This can be anything except a folder named "Debug" or "Release")
KMotionDLL.dll
KMotion_dotNet.dll
KMotion_dotNet_Interop.dll
GCodeInterpreter.dll
KMotionServer.exe
TCC67.exe
