Revision as of 11:45, 15 October 2018 by TK (Talk | contribs)
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
if (f)
    char s[81];
    fgets(s, 80, f);
1
2
3
4
5
6
7
8
#include "Kinematics.h"
#include "Kinematics3Rod.h"
#include "Kinematics5AxisTableBC.h"
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
#include "stdafx.h"
#define sqr(x) ((x)*(x))
// Construction/Destruction
    Act0Center.x = 12;
    Act0Center.y = 0;
    Act0Center.z = 0;
    Act1Center.x = 0;
    Act1Center.y = 12;
    Act1Center.z = 0;
    Act2Center.x = 11;
    Act2Center.y = 3;
    Act2Center.z = 12;
    m_MotionParams.MaxLinearLength = 0.25;  // limit the segment lengs for nonlinear systems
    m_MotionParams.MaxRapidFRO = 1.0;       // limit the increase in Rapid HW FRO
    GeoCorrect(x,y,z,&x,&y,&z);
    return 0;
